Hi all
new member here but I use vdj for over one year...
Since dj'ing with mouse and keyboard is hard I decided to buy a console....
So I had a look over the net and I found these consoles....
1)DM2 mixman (usb,cheap,quite good but not supporting mp3 and vdj)
http://www.mixman.com/products/dm2.html
2)Hercules mk2
3)xp10 (qood but expensive....)
http://eks.fi/index.php?page=xp10
4)Dac 2 (not so many features as dac3 )
http://djdeals.com/pcdjDAC2.htm
5)Dac 3 (good but small jog weel)
http://djdeals.com/pcdjDAC3.htm
what other options apart from that do I have???
Thanx in advance
2)Hercules mk2
Thanx in advance
geposted Wed 06 Sep 06 @ 10:55 pm
Thanx in advance
Thanx in advance
Well your first option is to become a legal version user, you will gain much more respect here in the vdj house.
Many users come "home" after finding these cracked versions, it's part of the master plan.
So you have that option to consider as well.
You are missing all the fun and benefits available to users with the real deal.
You could be using the new 4.0 now if you had taken advantage of the online special a couple of weeks ago.
Anyway, controller options vary greatly depending on what you do and how you dj.
From tt control to cd decks to rack and table top controllers, nobody supports as many as vdj.
Personally I like the dac 3 coupled up with the m audio xsession.
Gives you all the control you could possibly want.
Entry level cost wise, the Hercules mk2 or Behringer BCD 2000 are excellent options.
We all hope you make the right decision and join the family here soon.
Best Regards
geposted Wed 06 Sep 06 @ 11:07 pm
is it true that Behringer BCD 2000 has lag when you scratch?
geposted Thu 07 Sep 06 @ 9:36 pm
I ve heard that numark is gonna launch 2 brand new consoles ??? Do u know which are they?
geposted Fri 08 Sep 06 @ 8:16 pm
I think you mean Numark iCDX, it is CD and DVD player with midi capabilities so it can control VDJ without using timecode cd's. Check www.numark.com for more info.
geposted Sat 09 Sep 06 @ 8:24 am
just look at www.numark.com
geposted Sat 09 Sep 06 @ 11:04 am
nice ,I found them!
An other question, about x-session
WFT is it? I ve read some reviews but I didn't understand....
can u scratch with it????
I read
"The digital DJ revolution has arrived—and Evolution’s X-Session puts you in the center of the action with total control over today’s hottest music software. Scratch and cut using the classic 60mm cross-fader"
here
http://www.m-audio.com/products/en_us/XSession-main.html
how is it possible???
How can I prelisten the songs?Should I have 2 sound cards with that?
I read
here
geposted Mon 11 Sep 06 @ 9:47 pm
I think it is a midi controller only, so yes, you would need one sound card with at least 4 channels for both decks (2 x stereo). Maybe you should get Hercules MK2 and get both in the same unit ;)
geposted Tue 12 Sep 06 @ 6:04 am
MK2 is not so good for scratching. Rather get u46dj if you want to scratch. Otherwise MK2 is great.
geposted Tue 12 Sep 06 @ 1:22 pm
is it true that a new release of bcd2000 is on the way?????
geposted Mon 25 Sep 06 @ 4:38 pm
its underdevelopment
geposted Mon 25 Sep 06 @ 6:39 pm
dont bother with the xone 3d if you want to scratch with its jogs.
geposted Wed 27 Sep 06 @ 10:43 pm
