Hi all!
I use Hercules MK2 with timecode vinyls, but when I try to do some scratch, a strange sound occurs. Something like digital noise, but I can't here the real record during scratching just that weird sound, which is not similar to anything.
Can you help me in solving this problem?
Thnaks a lot!
Thnaks a lot!
geposted Thu 07 Sep 06 @ 3:44 pm
It is the latency, try to lower it down and use Asio for MK2 but remember, MK2 is not that good for hard scratching.
geposted Fri 08 Sep 06 @ 7:29 am
Hi!
Thank you, but can you tell me, how to lower the latency? And what do you mean by using Asio. When I use TCV, it uses Asio automatically, instead WDM. I know that Hercules is not to strong in scratching, but at least I would like to try it. :-)
So where can I adjust the latency?
Thanks!
Tom
Thanks!
Tom
geposted Sun 10 Sep 06 @ 11:17 am
Oh sorry, didn't saw you have Home version so no V4. V4 has this option, but check in your MK2 config for this settings, should be there. I don't own MK2 (yet), waiting for one...
geposted Sun 10 Sep 06 @ 9:49 pm
