in vdj3.4 the asio mode had no static noise for asio use.
now in vdj4.0 there is.
and after i exit vdj4.0 it changes the mk2 back to wdm and gives me an error.
please help.
please help.
geposted Thu 07 Sep 06 @ 9:10 pm
I the Vdj4 with mk2, I hear noise when I'm mixing, how can i fix that?
geposted Fri 08 Sep 06 @ 3:23 pm
ok, so here is the deal,
vdj 4 uses the hercules mk2 asio settings at max, but vdj 3.4 uses the min.
for that reason, vdj 3.4 with hercules mk2 in asio mode works just fine.
how to use the mk2 in wdm mode with vdj 4.0
[mk2 mixer] select wdm
[vdj] settings; performance; presets slider; 2nd from fastest.
tha'ts it.
DJ Shahar
www.djshahar.com
tha'ts it.
DJ Shahar
www.djshahar.com
geposted Fri 08 Sep 06 @ 9:51 pm
Thanks shahar!! please let me check..i hope that you can resolve that problem!
geposted Fri 08 Sep 06 @ 10:55 pm
shahar! las question!! what is wdm ??
geposted Fri 08 Sep 06 @ 10:56 pm
Let's make it easy: it is mode that has some lag if you know what i am talking about. There is more latency than in ASIO mode. That's for begining, otherwise there is GOOGLE and look 4 it :))
geposted Sat 09 Sep 06 @ 11:11 am
