Forum: Old versions
Topic: USB 2.0 With DJ Console?
Is the DJ Console compatibale with USB 2? Because you have a slight delay when using the Console. Thanks.
geposted Tue 06 Jul 04 @ 6:46 pm
Of course it is.
All USB1.1 are compatible with USB2.0
Is there a problem because console supports only USB 1? Is it better to buy pci USB card? It's only 15euro.
All USB1 are compatible with USB2.0
If I bought a usb 2.0 card and plugged my DJ Console into it, it'll run at usb 2 speed?
THANKS!
It'll only run at USB 1 Speed - I don't know if Hercules can put out a firmware update to USB 2 (I don't know if this can be done via firmware or whether it's a hardware thing)
Check the Hercules site for this - Hercules make the console and not the Virtual DJ people!
If you are getting delays follow the skipping solution tips - it's the top thread on the tech support section in this forum. IO don't get any delays or problems at all - your PC may just need setting up/optimising a bit that's all.
A good place to start is to defrag your hard drive.
usb 1 is good enough for playback...
if there are skippings in sound, is a computer problem
try disable "fancy extras" in windows, like grapic enhancements etc
there is a great post in "technical" forum for fine-tuning pc's
Thanks. :)
But it's not skipping in sound it's just a slight delay from when you press the buttons but's it's okay. We can live with! ;)
