Ok, so I tried today to setup two turntables and a mixer to my Mk2 to try out TCVs. But in the config section the TC quality fluctuates a bit. Not that much, but between 100% and 80%. During Playback the track sometimes gets a little bit "lost" if I rewind or stop the vinyl. And when its playing there are some "artifacts" and noises every now and then. I suspect it is a crappy needle, but maybe there is some way of fixing it software-wise. Any ideas?
Oh, and BTW. The 3/4 output on the Mk2 seems not to be working at all. Neither RCA or minijack. But that is quite cleara manufacturing defect (I have treated it with real care)
geposted Fri 08 Sep 06 @ 5:28 am
Are you using anti skip? What kind of needles? You could try to add more pressure to the needle.
geposted Fri 08 Sep 06 @ 5:30 am
