i am about to reinstall windows and reformat my hard drives,
coulds you please tell me which folders to save
ie c/program files/virtualdj/????????
and possibly the prosidure to put them back in after the reinstall, it should be cut and paste but.......
thx
therealbjthedj@hotmail.com
www.rumjungle.ca
thx
www.rumjungle.ca
geposted Sat 09 Sep 06 @ 11:58 pm
You can copy ur VDj folder, for the sake of your database, but your still gonna have to reinstall VDj for the registry entries. So make sure You have the full installation file handy, unless you want to try to export you registry entries too
geposted Sun 10 Sep 06 @ 12:03 am
man your fast,
thanks, will do
thanks, will do
geposted Sun 10 Sep 06 @ 12:19 am
No problem , good luck
geposted Sun 10 Sep 06 @ 1:06 am
