Which key assignment is for tapping BPM, I could not figure it out in the keyboard shortcuts tab. Essentially, I want to assign a key on the keyboard to "TAP" the BPM whenenver I want. Furthermore I would like to change the AUTOBEAT keys on my MK2 to do the same, (to tap the BPM).
YES I know you can click "edit BPM" and change it but that is to many clicks I want to be able to do ir right away. Either on the keyboard or on the MK2
geposted Sun 10 Sep 06 @ 6:40 am
I think the only way to do it is by going to edit bpm, but once you click on it, you can continue by pressing the spacebar. You can also assign a shortcut to "edit bpm".
geposted Sun 10 Sep 06 @ 9:15 am
SO I guess judging by the lack of responses there no key I can assign to do this, this feature should be a feature added in the next revision.
geposted Wed 13 Sep 06 @ 1:51 am
