Hey,
I've been using version 4 for a while now and its very good. Love the new engine. I'm having some major problems with it sliding out of sync when mixing hip hop and some times simple 4/4 dance/electro etc.! The BPM's are exactly matched etc but it's still happening! Never had these problems with 3.4!! Can someone help me please?!?! I'm supposed to be doing some electro.breaks demo's this week an I need to get this sorted asap!!
Thanks Guys,
Rory
Thanks Guys,
Rory
geposted Tue 12 Sep 06 @ 6:36 pm
Come on people!!! Anyone??
geposted Wed 13 Sep 06 @ 12:49 am
Well, when you scan your rap and Hip hop tracks you have to use "any music" engine to get the correct Bpm's. Even than can be mistake, if VDJ didn't put the * next to Bpm's in browser. If "Any music" engine doesn't help you, you will have to manually edit Bpm's (via Tap button).
geposted Wed 13 Sep 06 @ 1:11 am
Yeh, I have been using the any music engine. I'll give the tapping a go. Cheers
Rory
Rory
geposted Wed 13 Sep 06 @ 1:33 am
Somebody else on the forums recently mentioned about the "sync_no cbg" feature of VDJ, maybe this could help if your mixes are just slightly out.
This just lines up the the beats to the closest beat of the next song, ignoring the grid below each wavform.
To get that you need to make a shortcut to it on the keyboard or on your controller if you have one.
To do that,
Go to "config"
then click "keyboard shortcuts"
then click "Add"
now click," deck controls" from the white panel on the left
select "sync_nocbg"
press the button that you want to use to activate the feature.
click "ok"
and job done!
hope that helps. :)
To do that,
Go to "config"
then click "Add"
select "sync_nocbg"
click "ok"
and job done!
hope that helps. :)
geposted Wed 13 Sep 06 @ 1:41 am
I think I know what you mean an I'll give it a try. When I'm mixing hip-hop the big blocks on the waveforme are rarely aligned though! I match different bits of the waves up etc.
Thanks,
Rory
Thanks,
Rory
geposted Wed 13 Sep 06 @ 8:39 pm
