for those who don't have it and can't wait:
* http://www.virtualdj.com/features/hardware.html shows a new picture of something that looks like it might be the end product :)
* a few reviews of the XP10 non-vdj-version are available at http://eks.fi/index.php?page=xp10_impressions. sounds good :)
for the lucky ones who have it and can answer:
* does the tactile plate turn independently from the outside wheel, i.e. if I scratch on the top, does the side move too?
* is the scratch effect different whether vdj is set to 45 or 33 rpm feel? (kinda like you have to scratch a 33rpm record a little more gently than a 45rpm)
* is the range of the pitch slider linked to your vdj setting? i.e. can I set it to +8/-8, and if so how precise is it in that range (0.1 bpm, 0.01 bpm, 0.X bpm?)
* does it have a heavier and sturdier feel than the dj console?
thanks for any feedback...
geposted Wed 07 Jul 04 @ 8:55 pm
Nope, they are attached each other, it just depends on where you put you finger (side or plate). But they move together.
FRUiT94
FRUiT94
geposted Thu 08 Jul 04 @ 7:53 pm
No for the moment the scratch feeling is the same.
The pitch on the xp10 run from - 12% to + 12% with a 0.01% range
The jogwheel have a feel like the cdj1000 plate (more heavier than the dj console one)
geposted Fri 09 Jul 04 @ 10:23 am
and all that sounds sooooo great ;) look forward to the xp10 :)
geposted Fri 09 Jul 04 @ 12:49 pm
