I'm just ripping all my karaoke discs to the computer and I've tested a few with VDJ and most seem ok with the occasional audio blip - however, several have graphics doubled, ie: each line of the song is shown twice on the screen (one below the other) - meaning a song with a lot of lines per screen become unreadable because of the duplication.
Anyone seen this and found a fix?
Cheers.
Martin
Cheers.
Martin
geposted Wed 13 Sep 06 @ 2:24 pm
I'm using the 20 day demo so I'm hoping to be impressed in the next 20 days...
geposted Wed 13 Sep 06 @ 2:25 pm
It sounds more like bad rips to me. Use audiograbber to rip the cd+g file to mp3+g, THEN use mp3g2zip, freeware from here:-
http://www.softpedia.com/get/Multimedia/Audio/Other-AUDIO-Tools/MP3-GDG-to-ZIP.shtml
Then go to config in VDG and set the .zip suffix to "karaoke"
It will play the files perfectly.
geposted Wed 13 Sep 06 @ 2:34 pm
I've downloaded Audiograbber and mp3g2zip and I'll try it later today.
I had suspected the ripping - so we shall see.
Just out of curiosity, is my laptop up to using VDJ for DJing and Karaoke?
Intel 1.8g Duo Core
1g RAM
128mb graphics
100gb int hard drive
250gb USB 2.0 hard drive
Thanks for the help.
Intel 1.8g Duo Core
1g RAM
128mb graphics
geposted Wed 13 Sep 06 @ 2:57 pm
Intel 1.8g Duo Core
1g RAM
128mb graphics
Intel 1.8g Duo Core
1g RAM
128mb graphics
My opinion only... borderline
geposted Wed 13 Sep 06 @ 3:35 pm
Are those SAV discs you are trying to rip??? I had problems trying to rip those into my computer and never could figure out how to get rid of the double lines.
geposted Wed 13 Sep 06 @ 10:06 pm
Holy crap Brian! And I thought "I" had problems!
geposted Wed 13 Sep 06 @ 10:13 pm
It is something in the coding from the manufacturer. Unfortunately I havent heard of any solution.
geposted Thu 14 Sep 06 @ 12:35 am
