I would like to know how to make a shortcut to mix video only w/out the audio like if you click on one of the small windows in the default video skin in 4. Is there a way to do this as the transitions are smooth as butter and all I would have to do is mix the audio??? Thanks
geposted Wed 13 Sep 06 @ 10:06 pm
Make a shortcut in Video>Video_Crossfade and put in the amount for it (you have to try what speed fits best for you).
geposted Thu 14 Sep 06 @ 3:10 am
I don't see any way to change the speed of the fade all the numbers do is tell it where to go. I am trying to find a way to map a button to slowly crossfade the video only.
geposted Thu 14 Sep 06 @ 5:30 am
