On my previous version 3.4 i use to have a shortcut key to cue or enter a new cue on the deck #1 or deck #2 depends witch one was playing...well ok that was easy, every time when let say my deck #2 was playing live i can use that specific shortcut key to gue the song on deck #1... same thing on my deck #1 while deck #2 is playing live. That was switching automaticaly by the software.
Now the new version 4.0 is not doing the same thing anymore, i have to manualy switch from deck#1 to deck#2 or vice versa using the default key "TAB".
Can i have that automatic switching back on the 4.0 somehow ?
geposted Thu 14 Sep 06 @ 12:45 am
Default deck means the deck which is highlighted, Active deck means the one which is playing. You have options now "On Deck 1" or "On Deck 2", assign the keys for both and try it then.
geposted Thu 14 Sep 06 @ 3:07 am
@Funky t,
go to the options and set "autoheadphones" to "on load" This is the same as in 3.4 and also my prefference. Default (new) option in 4.0 is "always" but somehow you disabled it.
geposted Thu 14 Sep 06 @ 3:59 am
Thank you ..."APOPSIS" this is it...
...also, keep up the good work with the "skins", this is what we need, us the "Time coders".
geposted Thu 14 Sep 06 @ 5:47 am
In fact, it's better to define like that:
"default deck" is the one used to prelisten and "active deck" is the other one
geposted Fri 15 Sep 06 @ 12:36 am
