hey guys multi instance would be great for 2.0 since u could sycronize
can someone please make it
please
morris dosnt wanna do it anymore he's 2 busy
i was hoping fruit would be interested
thanx anyway
dj smokey
please
thanx anyway
dj smokey
geposted Thu 08 Jul 04 @ 8:19 pm
anyone?
geposted Fri 20 Aug 04 @ 6:40 am
I would love to do it.........
but.....i'm a console user.
so !!!! if you sent me a full version.
it's done while you're sleepin.
geposted Fri 20 Aug 04 @ 6:46 pm
well...
i downloaded the trail and this skin works cool to me.
whats the problem ????
geposted Fri 20 Aug 04 @ 7:15 pm
Which trial version did you try (the version is written on the splash screen)? The Multi-Instance Skin is not compatible with VirtualDJ 2.xx.
geposted Fri 20 Aug 04 @ 7:54 pm
i wish i know how to do it :(((((((((((((((((
i know fruit could make an amazing one
pleaseeeeeeeee
thanx dj smokey
pleaseeeeeeeee
thanx dj smokey
geposted Sun 22 Aug 04 @ 3:01 am
An update of this skin is now avaiable for VDJ v2.xx. Have a look in my blog for a preview (level 2 minimum)
http://www.virtualdj.com/blog/djcel/?category=0
geposted Fri 04 Mar 05 @ 3:50 am
[ENG] for a better customable skin and for multi-instance-use, I think is necessary a browser that allow the Drag&Drop between the instances : will be possible with a new version? o a supplementary program like vdjBrowser.exe ???
I searched a program for a mp3-catalogue with "seach option" like vdj , but I can't find anything...
[ITA]per una migliore personalizzazione delle skin e per la multi istanza, credo che dovrebbero permettere il drag-e-drog da una istanza all'altra così che ti spari la finestra (e solo una x la multi istanza) dove ti pare. sarà posssibile in futuro?
Ho cercato un progr. x catalogare gli mp3 ma nn nn ho trovato niente con anche l'opzione "search" like vdj...
geposted Wed 20 Apr 05 @ 12:27 pm
You can use the windows explorer for drag'n'drop on the two skins
geposted Wed 20 Apr 05 @ 1:27 pm
ok, but the win-explore use too much screen and in search is not so comfortable, and than go from the search mode to the tree mode is more uncomfortable.
I try many time to find the way to write a php or an asp code but I'm not able to obtain a result like file-object but only "link".
Any suggest?
Any suggest?
geposted Thu 21 Apr 05 @ 2:56 pm
Yeah I think a new Multi-Instance skin is a cool idea, it would be cool if there was a way to just design it as 1 skin with 4 players and have it automatically realise it needs to run 2 VDJ...2 searches is a bit of a waste of space.
The VDJBrowser idea is a coll aproach, as long as it has SAYT (Search As You Type)...I think the browser needs a few improvements as it stands...like auto Asterisking (*) in searches...a cool one would be able to search Dancin' and Dancing at the same time automatically and Mr Bright Side and Mr. Bright Side
As sometimes your desired results don't show up depending on the naming.
geposted Fri 22 Apr 05 @ 10:33 pm
@DJ Ross M, you should write your second idea (for the searches) in the topic "new features" ;-)
geposted Sat 23 Apr 05 @ 7:54 am
Ross,
someone for multi instance setting does so:
open vdj, set everything: audio, plug-ings, samples, fxs and skin.
shut-up vdj and go to regedit and save like vdj1.reg on desktop the folder
\HKEY_CURRENT_USER\Software\virtualdj....
then re-open vdj and set everythings about his 2nd instance, shut-up vdj and save all keys in a file like vdj2.reg.
now when you want start the 1 configuration run vdj1.reg then virtualdj.exe, the same for the 2nd configuration
but we want a power-full and easy-full vdjbrowser ;P byez
geposted Tue 26 Apr 05 @ 10:33 am
"we want" ?? A no license user should say "we would like" :-)
geposted Tue 26 Apr 05 @ 11:18 am
I think I have just worked out a clever way to do this project that could lead to some very interesting results for a lot of users.
This would have to be suggested as a new feature to make it work.
What if...VDJ had sticky windows, that way you could easily align different instances of VDJ to part of you screen - for ease of use.
They would also have to be stretchable (dynamically)
I've never actually designed a working skin but what about making a 2 or 3 part skin.
A Skin that is purely the players and then a skin that was just a browser, playlist thingy
I've used these values for simple adding Screen Res 1200 x 900
Player part 500 x 900 browser 200 x 900 or whatever.
Only one huge prob I see and this comes down to how VDJ actually works...FX and samples are all handled through the browser area so if you only had one browser how could you adjust the properties of all decks??
Do you think VDJ after 2.07 when they go for the next big release let's say 3.0 or even 4.0 would consider major app restructure. Something like VDJ - Pro Studio?
Ross.
Ross.
geposted Tue 26 Apr 05 @ 1:24 pm
dear djcel:
1st) I don't speak english very well, ... so I'm sorry.
2nd) I'd not like burn my mind to find exactly formal expressions ;P
3rd) I prefer "Want" because the Trade has to satisfy the probably-future custumer ..., or not ?!?
anyway..., thanx 4 your attention =)
Ross: I think that probably your suggests may be affect in someway the simplicity of the program.
I don't work like dj but in my last parties I understood that with alcool and havy volume everythings have to be simply, elementary and intuitive start from cds, cdjs, mixers, ecc...
ciao ciao
ciao ciao
geposted Wed 27 Apr 05 @ 11:55 am
Ok a new update for vdj v3.0 is coming soon
It will use the power of new skin engine for multi-instance but no more functions in more for the moment.
geposted Sat 23 Jul 05 @ 1:41 pm
Lets make sure the update can Syncronize 3 or more instances with local I.P.
Right now you can only do this with 2 instances.
geposted Sat 30 Jul 05 @ 3:59 am
Sorry the skin doesn't change that ;-)
I have uploaded the update for virtualdj v3.0x
geposted Mon 01 Aug 05 @ 10:08 am
You can drag'n'drop song from an instance to another one.
I only let the second browser for the samples and effects
geposted Sat 06 Aug 05 @ 11:28 am
