So, I've finally started playing around with V.4. Looks good. Sounds even better, but I feel like if I choose the higher performance settings to give me better quality, my video performance suffers.
Computer Specs
AMD Athlon 64 3200+
2GB DDR400 Ram
3 250GB SATA Hard Drives
GeForce 7800 GT PCIE Video Card with 256MB Ram
M-Audio Delta 1010LT
I tried the performance slider at the highest from the max setting - I notch to the left of absolute right and when I play 2 videos, they both slow down.
If I move it one notch to the left - I get fast video speed, but I feel like the master tempo doesnt work as well and the sound quality goes down...
Thoughts???
Computer Specs
AMD Athlon 64 3200+
2GB DDR400 Ram
Thoughts???
geposted Fri 15 Sep 06 @ 8:07 am
Simply, Athlon 64 3200+ is not up to the task! For highest performance, I think that Dual Core Intel 915 D with 4Mb cache and 2.8 Ghz will be enough but not sure :) . I have that in the other machine and I will try it to see how it is performing. Stay tuned :)
geposted Fri 15 Sep 06 @ 8:24 am
Hmmmmm...works great for the videos on v3.4 - is v4 that much more computer intensive ? DO NOT want to spend any more money on PC parts - Maybe I'll just wait for the Mac version since I have 2 dual core Intel Macs.
Should I give up now on the Athlon 64 3200+ ??
geposted Fri 15 Sep 06 @ 9:25 am
Better master tempo wasn't in 3.4 either.
just saw this sweet deal on new egg
http://www.newegg.com/Product/Product.asp?Item=N82E16819103539
geposted Fri 15 Sep 06 @ 5:01 pm
Lol and I bought 2 :)
geposted Fri 15 Sep 06 @ 8:11 pm
Best quality options are made to reach the top of the the must powerful processors. VDJ 4 even in it's fastest settings (opposit than quality) sounds better than VDJ 3.4. So please try to use a setting in there that let you work better, don't blame VDJ 4 or even AMD 3200+ processor.
If you want MAC version because of Dual Core processors, don't wait and buy now any of the laptops with Core Duo processors now, for sure a lot of more performance than your current Pc.
In a Few you are going to see Core 2 Duo on laptops too. But as I said before, just adjust your settings as well as it could be with your actual hardware and don't buy anything yet.
Good Luck!
geposted Sun 17 Sep 06 @ 11:07 am
So Cyder - will this work ?
http://www.newegg.com/Product/Product.asp?Item=N82E16819103751
I am pretty sure I can use this proc with my current MOBO.
http://www.msicomputer.com/product/p_spec.asp?model=K8N_Neo4_Platinum&class=mb
Or should I get a new AM2 board ?
Thanks for the insight. Get at me sometime...
geposted Mon 18 Sep 06 @ 9:00 pm
That is a hell of a nice processor, but its not going to work with your current board as its the new am2 socket. Personally I would wait till the second generation of am2 boards to switch (probably around christmas) I'll be watching these boards closely.
geposted Mon 18 Sep 06 @ 9:27 pm
