How do i broadcast with shoutcast through Virtual DJ.
Winamp is fine but i want to know how to do it with Virtual DJ 4.0.
Cheers guys.
Cheers guys.
geposted Fri 15 Sep 06 @ 8:34 am
Why do they have broadcast its stupid..
You click the link with your ip form another pc and it juss downloads for infinite time without playing at all.
It says size not known shdnt it be playing in winamp or something and buffering?
geposted Fri 15 Sep 06 @ 6:46 pm
we use Vdj broadcasting
profesionaly
and it works
just
fine and its a brilliant feature
aslo using cracked copies of the software ? , you cant complain if it doesnt work,
profesionaly
and it works
just
geposted Tue 19 Sep 06 @ 11:46 am
Firstly please add your serial
to your page
then secondly , go to the recording tab
and press broadcast and press config , now you can choose to broadcast to a server or from your own machine
then press ok
then press start recording.
hope that helps
to your page
then press ok
hope that helps
Cheers guys.
Cheers guys.
geposted Tue 19 Sep 06 @ 11:48 am
Hey its dj majuu here !! can u guyz help me with virtual dj broadcasting ..i am having a mp3 shoutcast plugin but when i press the recording button its give dis message "broadcasting error" **encoder error** plz help meee!!!!!!!!!
geposted Sat 23 Sep 06 @ 9:31 pm
download the lame encoder from google
its in the form of lameenc.dll
simply paste that into the vdj program folder:)
geposted Sun 24 Sep 06 @ 12:52 am
You are posting the same problem in different threads.
It's getting annoying!
geposted Sun 24 Sep 06 @ 3:23 pm
