hey guys, i got a numark cdmix1 djpack, and im wondering if i can connect it to my desktop to use in conjunction with VDJ?
can it be done, and how can i go about setting it up?/
thnks
Alex
thnks
Alex
geposted Sat 16 Sep 06 @ 4:30 am
I think you can't because you have only one master out (quote:"Master balanced/unbalanced and record output") and you don't have separate output for both cd players which is needed for TC cd use. And above all, you must have a Pro license to be able to do that because trial supports only one TCV/TC for 5 minutes.
geposted Sat 16 Sep 06 @ 6:08 am
yea im planning of purchasing vdj pro if i can connect it to my pack. Like in the back of my numark i see this; (W) indicates white RCA plugs (R) indicates red rca plugs
Record Master
Left (w) (w) (w) (w)
Right (R) (R) (R) (R)
The record RCA's are taken because I hooked it up to my comp (in order to record sets)
I believe the first 2 sets of rca plugs are for chanel's 1 and 2. Would this help?
Thanks,
Alex
Record Master
Thanks,
Alex
geposted Sat 16 Sep 06 @ 3:43 pm
sorry, the record is the 3rd set of Red and White RCA plugs, and the master is of the last set of RCA Plugs
geposted Sat 16 Sep 06 @ 3:44 pm
bump4help
geposted Sun 17 Sep 06 @ 3:26 pm
If you have separate RCA's for cd players than yes, you can use it with TC cd.
geposted Mon 18 Sep 06 @ 12:57 am
