Hello Guys,
I am trying to setup Virtual DJ with the use of two soundcards, the Creative Audigy 2 and The 4 version with Time Coded Vinyl.
If i play individuel input channel it al works fine, but if I want to use both channels at the same time it doesn't work because I can only play one channel at the same time.
Is it possible to use Virtual DJ with two soundcards and time coded vinyl with two mixtables at the same time?
I use one input channel left on the first soundcard and the other input on the second soundcard, but I can only config in Virtual DJ one channel at the same time.
Thx for your support.
geposted Sat 16 Sep 06 @ 2:05 pm
I am using version 3.0 of Virtual DJ.
geposted Sat 16 Sep 06 @ 2:06 pm
No support for cracked versions
geposted Sat 16 Sep 06 @ 2:07 pm
Nice try, but them demo only support one tcv or tccd for only 5 minutes, so to enjoy the full support of all the users and gain access to all the downloads, buy it, it's well worth it
geposted Sat 16 Sep 06 @ 6:04 pm
