try mixing to songs at the same time, do this by killing the base on the other one and using only te vocals...do this for the next to songs make sure that you pitches are the same for all the four songs....having these two mixes, mix the two mixes that will give you 4 songs playing the same time
geposted Tue 19 Sep 06 @ 10:26 am
Huh? If You want to mix four at once just use the mulit-instance skins
geposted Sat 23 Sep 06 @ 1:03 am
4 at the same time? it should be strong mix :D
yes, with multi instance skin it is possible.
geposted Sat 23 Sep 06 @ 1:41 pm
