I have VDJ4.0 installed, the program loads, I can load a song onto a deck, but it will not even play....I need assistance. I have it set to the internal sound card just to play with it. I have tried changing the setting in the config menu....NOTHING! I am getting frustrated!
Any suggestions?
Randy
Any suggestions?
Randy
geposted Wed 20 Sep 06 @ 1:54 am
what setup do u have? pc specs and hardware used?
geposted Wed 20 Sep 06 @ 5:04 am
check to be sure you don't have time code enabled unless you are using time codes, the inputs should be set to none.
geposted Wed 20 Sep 06 @ 5:31 am
