Okay I finally found out how to install the new sound effects. But, on the contrary alot of the effects I downloaded wouldn't install. Are you guys aware of this problem? Why do some of them not install and some do install??
geposted Wed 20 Sep 06 @ 5:47 am
Some of the old effects wants to install in 3.4 folder and you probably have V4. They need to be updated because registry location of VDJ has been changed in V4. In the mean time, if you wanna use them, install 3.4 version in different folder and install all the plugins inside then go in VDJ 3.4 folder>effects and copy all the dll's inside to your V4 sound effect folder.
geposted Wed 20 Sep 06 @ 6:35 am
I hope they will change those effects soon. Many posts about them :)
geposted Wed 20 Sep 06 @ 12:27 pm
