hi , just getting set up with vdj xp10s and laptop. i have some questions:
i am sure the solution are obvious but being new to this software i dont have a clue.
1-master tempo doesnt work when i try to speed up the tune using outer rim on xp10, the pitch changes. how to i solve this?
2- while i was trying to solve no.1 i changed the centre touch pad mapping, now i dont know what it was on when i started, i would like to put it back to default so you can stop the tune just by touching it then it will start again when you let go.
3-last thing , the speed at which the outer rim reacts is too sensitive i.e. you only have to gently touch it and the song accelerates like a porsche, is this adjustable at all.
thanks
steph (bar dj from london)
thanks
geposted Thu 21 Sep 06 @ 9:11 pm
1. Turn "Keylock" on skin in VDJ, this is Master Tempo in V4.
About other, you can reinstall VDJ and it will reset mapping for XP10, I think, not sure.
geposted Fri 22 Sep 06 @ 2:44 am
