I have 2 direct drive tt and i have tcv on their way to my house and i want to now what i need to get them connected to my laptop? and keep in mind i have a little budget! Ive been thinking about these sound cards:
Behringer (UCA202) Sound Card - $30.00
or 2 USB 2.0 Audio Sound Card Controller PC Adaptor - $15.00 (each)
well these are the cheapest way i found but i dont even know if they will work can some one help me please
geposted Sat 23 Sep 06 @ 6:38 pm
go for ESI U46DJ and full version of VDJ PRO.
geposted Sat 23 Sep 06 @ 6:51 pm
but will those work that i mentioned
geposted Sat 23 Sep 06 @ 6:57 pm
you want a sound card that has good latency , a 15 dollar usb card is not the way to go
geposted Sat 23 Sep 06 @ 7:00 pm
well i need some thing good and cheap so which way should i go
geposted Sat 23 Sep 06 @ 7:01 pm
exactly what i wrote before. and it will work 100%
geposted Sat 23 Sep 06 @ 7:25 pm
Xeon's right theres no way around it, cheap isnt the way to go when it comes to timecode, and before you know it the 20 day limit on your demo will run out so you might as well save for the software and a real soundcard you can even have a look at ebay for a good card
geposted Sat 23 Sep 06 @ 7:28 pm
