I have purchased atomixmp3 only to find out it is very limited to what type of music files it will sync with. How can I change all of my mp4 files to mp3 files in order to make this atomixmp3 not completely useless to me.
geposted Sat 23 Sep 06 @ 9:05 pm
you should have went for the home version of VDJ, never the less if you choose to switch over you will get a discount, You can use I-tunes to change them to mp3 first you have to go to your options and make sure the import (prefrences/advance/import) is set for mp3 then go the the advanced tab and it should say convert selection to mp3
geposted Sat 23 Sep 06 @ 9:39 pm
BTW These are mp4 not m4p right? cause m4p files are protected and even VDJ wont play these and Itunes won't convert
geposted Sat 23 Sep 06 @ 9:42 pm
