Just some short questions...
Is the DJ Control a Midi-Interface Mixer??
And if yes, is it possible that i use it in corp. with my Behringer VMX200 Mixer?
Or is it a better solution to buy the DJ MkII Console?
thx for your time and anwsers
thumbs up
thumbs up
geposted Tue 26 Sep 06 @ 11:24 am
[color=orange]the mp3 contol , is a midi controler only yes
you could use it with the mixer , as the mp3 control is not a sound card you will need to conect your computers soundcard to your mixer directly
alternatively
you could buy the mk2
have the benifit of a built in sound card
and the ability of using timecoded vinyl easily if you decide to buy them
you idealy need pro for both setups
but if you buy the mk2 console you get a free copy of home edition
which i belive you can upgrade for a reduced price.
alternatively
geposted Tue 26 Sep 06 @ 11:35 am
So if i understand correctly...
If i plugin the Mp3 Control i can mix the tracks with VDJ and the music will come out of my Soundcard?
So you mean if im not too stupid ;) that i connect my mixer to the Soundcard and the Output of the Mixer to the Speakers?
geposted Tue 26 Sep 06 @ 11:48 am
Yes, you will only control VDJ, sound card will give you the sound.
geposted Thu 28 Sep 06 @ 3:35 am
