I used to work with a VDJ 3,0 ( a crack version i had (shame on me)) .
for streaming, on a web radio in montreal, i was directly streaming with vdj.
A shoucast window ( same has the one in winamp) was opening and i was entering my set up adjusting output volume , then connect. Everything worked fine!
Since i bought a legal version 3.4 to encourage the good work you guys do, it doesent use that windows anymore. It use a new stream windows that i cant add some info like IM and IRC name etc.
And with the new stream i CANT adjust the output volume and it always show my title and author ( what i dont want) .
So the only way for me to put my info that a want to stream and hide the title and author , is to use the winamp shoutcast dsp module.
BUT when i stream with this, My Pc is slowed down, cuz of winamp that is open.
Can i fix de problem in a way?
Can i use shoutcast stremer,without winamp open?
Or easyest way, can i at lease shutdown the display of title author ?
THX for the precise and fast response from u VDJ PROS
geposted Fri 29 Sep 06 @ 5:18 am
