Topic: Attention Niems
Hi Niems,
So far you been the only 1 to help, so I'll tell you my progress reagrding crazy sound coming from system hooked up to U46DJ and laptop. I duplicted the scenario on my desktop and it seems to work pretty well (just tested for a few minutes).
What do you think the difference is between the 2? I did install the first driver on the laptop before learning of 1.016, after hearing of this I did an uninstall of the driver and put the newer one on. would that have anything to do with this problem?
Thanks for your help.
geposted Fri 29 Sep 06 @ 2:29 pm
