Forum: Old versions
Topic: mixer or midid interface
hi i just wanted to ask if there is more than one mixer that can be connected to the computer with either USB or other way and used to control virtual dj - if anyone knows anithing about it please let me know.
also wanted to know about setup using TCV.
when you use turntables and adjust the pitch does that speed up the song playing on virtual dj or you have to speed it up using controls in the program.
and one more thing -
i want to try using TCCD as well but don't know where to get them .
thank you heaps
geposted Sat 30 Sep 06 @ 5:16 am
If you want to control VDj with an external controller you have to have a device that can handle MIDI signals
More than likely you will have to map it yourself, if there isnt a plugin for it
every mixer that is midi compatible can controll VDJ. For some of them there are allready plugins written.
For using VDJ with TCV you need 2 turntables and sound card with 2 stereo ins and 2 stereo outs. Maya44 or u46dj ate tested and work 100%.
it changes speed of song in VDJ. You don't need to do anything else.
setup for TCCDs is the same as with TCVs. You can get signal in mp3 here:
https://virtualdj.com/products/timecode/VDJTimeCode.mp3
Clck Save target as. Then record it as AUDIO cd.
