Since I calculated all my bpm myself in the past, if I add my count into vdj will it use my calculations or will it just try to recalculate it again?
geposted Wed 14 Jul 04 @ 3:21 am
If you edit the BPM's in VDJ, it should stay there until you force VDJ to re-analyze a file.
macourteau
macourteau
geposted Wed 14 Jul 04 @ 3:32 am
Thanks, I was just wondering if vdj would still be able to sync and lock if I just entered my own bpm's.
geposted Wed 14 Jul 04 @ 3:18 pm
yes...
but remember to align CBG to fit under the beats... or looping/mixing can go wrong... even use of samples :)
if you are a perfectionist, make the BIG cbg aligned to first beat of each measure... (the first beat of the song, have a BIG cbg)
geposted Wed 14 Jul 04 @ 3:28 pm
