Hi there, Im using virtualdj and hercules dj console since 3 years ago, i get the new MK2 console and try the pro version of virtualdj 4, all works good except that I can not select the audio source to my headphones, I mean i can not listen the next song, just the actual one, anyone can help?
geposted Wed 04 Oct 06 @ 6:07 am
Search in the blogs for an answer.
Good luck
Good luck
geposted Wed 04 Oct 06 @ 11:19 am
Next time please don't make the same question in two topic ;)
Here your solution: https://virtualdj.com/blog/cioce/?category=2
geposted Wed 04 Oct 06 @ 11:35 am
my mistake sorry first time user
geposted Wed 04 Oct 06 @ 6:16 pm
Hi there, the problem stills i just want to select the headphone source whit the headphones connected to the dj console, has a button to select betwen deck a, deck b, mix, & split modes to the headphne
Thanks Again
Thanks Again
geposted Wed 04 Oct 06 @ 6:51 pm
hello,
i have the same problem and the link you've posted doesnt help :(
geposted Sat 07 Oct 06 @ 9:23 pm
Reinstall the pc's audio drivers - i solved that problem with this way in my laptop.
geposted Tue 10 Oct 06 @ 12:27 pm
