Forum: Old versions
Topic: Numark CUE
alx2kPRO InfinityMember since 2004
I was just messing around, when I entered Numark webpage, and I found that they are anouncing their new software "numark cue" looking just like VDJ with a diferent skin (I must admit that I like the scratch-elapsed time-bpms circle).
I thought they were going to release the software only with virtual vinyl and under the "virtual vinyl" name as part of the hardware-software pack.
anyone at the staff knows any diference between vdj and numark cue? pricing?
Thanks.
geposted Fri 06 Oct 06 @ 12:19 am
its pretty much the same thing :)
geposted Fri 06 Oct 06 @ 1:08 am
alexis7Home userMember since 2006
can you use the same Timecoded Vinyls in Atomix VDJ,Numark VV & Numark Cue?
I mean for example if you have numark virtual vinyl TCV can you use it with VirtualDJ or Numark CUE?
thanks
geposted Fri 13 Oct 06 @ 4:23 pm
yes ;)
geposted Fri 13 Oct 06 @ 5:33 pm
