Hi,
what about making a 'Goto + (or -) x beats' function ? (something that could be shownd like the cues, with the label 'Goto1 + 4 beats' and the destination labelled 'Dest1'). This 'Goto' should be saved, associated with the music (exactly like the cues). There was a plugin (I think 'Cues + Event' by DjCel) that (I suppose) could be that but it does not work with the v4.0.
In this way, you could predefine loops ( + or -) what are perfectly in the beat, wherever you are in the music.
What do you think about this idea ?
Guz
Guz
geposted Fri 06 Oct 06 @ 10:39 am
You have Skip option which is similar to your request, you can make a shortcut for it.
geposted Fri 06 Oct 06 @ 7:20 pm
Well, the aim is to SAVE the loop in fact, and you could have several loops predefined for 1 track.
geposted Fri 06 Oct 06 @ 7:31 pm
almost like looped samples? set the key turning the loop on and off to also pause and resume the track and there should be no gap,
no idea if that would work but it will do until they sort it out properly
geposted Sun 08 Oct 06 @ 11:45 pm
