Hi, i have a big Problem with Vdj 4,1 and BCD 2000 Behringer...
when i try to charge a mp3 file in vdj deck, Vdj is freezing or freezing in a few second after the start a deck..this problem( i'm sure ) is generated when i charge files that come from another hdisk on my pc.
If i put many mp3s file in vdj from the same hd of the os. and vdj program there is no problem and Vdj work 100% with this behringer console.
when use a Mk2 this strange problem is not present..mk2 work with all file come from many hd in my pc without freezing.
This prob with a bcd console it's repetitive.
Thank a lot and sorry for my bad bad english.
A special Thank to Vdj staff for this new release very very good work!!!
geposted Wed 11 Oct 06 @ 10:04 am
Is the second hard drive a external one?
geposted Wed 11 Oct 06 @ 10:55 am
max 25 sec worked than stoped
i am gonna loose my mind
geposted Wed 11 Oct 06 @ 1:09 pm
it's not external drive.
ciao
ciao
geposted Wed 11 Oct 06 @ 1:19 pm
Have a look at you IRQ setting and make sure that the 2 dont share and IRQ
geposted Wed 11 Oct 06 @ 2:56 pm
in performance-tab. make sure you uncheck 'overclock' it helped for me... i also have a bcd2000, same problem.
geposted Thu 12 Oct 06 @ 6:29 am
I had same problem... deactivating wifi solved it.
BCD looks gorgeus and more pro than mk2 but i've been playing last 2 years with Hercules and i had not such problems as with bcd, a pity
geposted Mon 16 Oct 06 @ 11:15 pm
xylio drivers need to be improved, meanwhile check this guide, bcd should work:
https://virtualdj.com/forums/57850/General_Discussion/A_quide_to_setting_up_BCD2000_in_Virtual_DJ_4_1.html
geposted Tue 17 Oct 06 @ 2:22 am
No way...still freezes, mp3 freezes, videos even more...(powerfull tool for a pro dj nowadays to offer video-deejing event, i allways wil thank VDJ to be the first on this). freez and crash are bad to happen when you are live at the club FULL of people....its a shame that for now BCD seems not to be fully compatible with VDJ. Of course its a matter of Behringer team work on it, specially theyr drivers.
I wrote to them....lets see the answer
Please, please, please...have a deal to work on it Behringer Team and VDj Team.
for now and after this awful experience...i'm back to my old MK2 on VDJ 3.4... let's wait for developement (if i could write code....)
geposted Fri 20 Oct 06 @ 1:44 am
There is conflict with some motherboards, perhaps yours is one of them.
geposted Fri 20 Oct 06 @ 2:12 am
I'm using Sony Vaio FE11S Laptop
geposted Fri 20 Oct 06 @ 2:14 am
Most laptops have that problem, check if your irq is not shared and use 2.0 usb port.
geposted Fri 20 Oct 06 @ 2:16 am
how can i check about irq?
geposted Fri 20 Oct 06 @ 2:18 am
And disable Lan and WiFI (that often uses the usb in laptops)
geposted Fri 20 Oct 06 @ 8:01 am
