Forum: Old versions
Topic: no video
I'm trying to get some video clips displayd in VDJ.
format is mpg.
But when Idrop them onto a deck, no clip is played....
I had it working in the past, but think it was with version before 4.0.
Any points to look at to troubleshoot?
All help is welcome. Thanks.
geposted Thu 12 Oct 06 @ 9:59 pm
try disabling your hardware accel, but first make sure that the video window is enabled
sorry, played with those two settings already. no cure.
Screen resolution is at 1440 X 900 (widescreen). If that could cause any problem....
recall that in the past lowering the display resolution cured the problem. But now it doesn't help.
can you get a bitmap up on the preview screen?
none of the video effects work.
The Only thing I can on display are the title and artist of the song...
DX9 is the latest?
yep, the latest.
9.0c (4.09.0000.0904)
format of the video is MPEG-1 Layer 2.
Gspot informs that codecs are installed correctly.
FOUND THE SOLUTION.....
a part of the hardware accel. was still enabled.
How I found out....
started the info dialog from the command prompt: Start->Run->dxdiag
in the tab display, it showed under Direct-X-functions that all acc. were enabled.
Just disabled them all, restarted VDJ, and clips are displayed now....
Thanks for all the help.
glad you figured that out
what type of video card is anyway? kind of strange to have to disable accel.
I am having similar issue. Except I cannot even see mp4 video files i downloaded via itunes. I cannot see the videos for the quicktime files either. I tried what this guy did and it did not work. I am using the download version i just bought tonight.
I use Gforce
PS. I cannot download any freebees can u unlock my account?????
FYI... The note to the side is incorrect I just purchased the software
O- also I cannot see the visualizer......
You need to add your serial to your profile on this forum and you will then get all the goodies & secrets.
Thanks for the info.... Now I will try to find out how to get the VJ to work. Usually when you let a software search the web it does it for you...
No harm done, welcome to the gang.
indeed strange to have to disable hardware acc.
Card = nVidia GForce4 MX 400
I still could not get the video stuff to work. I could get the songs to come up on the screen and doing a ctrl??? i could temporarily get the visual to launch.....
Also Will you be supporting .swf or .fla (flash) file extensions soon>>>> I have some cool things I have made using flash and would like to incorporate it.
O- Thanks for accepting me into your gang....
