Hi for all...well, I´m divulging a new skin....and I make some comentaries......
Many peoples like the famous "Tecnhics" and I think why no one made before?
On start, I decide to do using a model with "CD". But I din´t find one nice PIC and I believe:
"great skins must be have details to be looked at"...I had found a photo good, where 12 had been necessary printscreens (6 in vertical line and 6 in the horizontal line finally to obtain to good photo with details)...So, I decided made using Technics with model "12"...
As I know... that a legion of admirers of the Tecnhics ....I did not want to change nothing
of its appearance and I using until the proper buttons, as it is the case os desk "active desks"...
I made in the size 1280 x 1024....and I know perhaps that MANY people can´t use...however the format
of the Technics was necessary because it is occupies increased space when and that is necessary
to get details. I include video functions too...and I find a trend future...
I hope that all like (I do)....make any suggestions you want...
The file was send to VDJ site and them are thinking....(it still did not have time for the post.....and also is not certainty they to like and dispatches by post)....but I wanted to make these comentarios
Thansk for All
Cristian
preview of skin follows one
Thansk for All
Cristian
geposted Fri 13 Oct 06 @ 6:46 pm
wow! ;) thats a nice skin! great job
geposted Fri 13 Oct 06 @ 7:23 pm
I forgot to say......who don´t have a 17" video, perhaps not be nice!
geposted Fri 13 Oct 06 @ 7:32 pm
Wowwwwwwww good jobs men...
send me a download link
geposted Fri 13 Oct 06 @ 10:44 pm
Nice work give us a link:-)
geposted Sat 14 Oct 06 @ 1:02 pm
I see you have submitted the skin, but there is lots of things not working yet;)
- Nudge jogs dont work
- BPM reading on mixer dont work
- FX selector on mixer dont work
etc
Was it submitted before it was finished?
(BTW, great looking skin)
geposted Sat 14 Oct 06 @ 2:15 pm
Yess Yess Yessss very Nice when, comes the download link ?
In 1024x768 ;)
In 1024x768 ;)
geposted Sat 14 Oct 06 @ 9:45 pm
I don´t understand.....
BPM in top of waveform and in mixer is ok here...
Nudges is functioning here too......but...when marked with is it option in the
extended part of mixer......
What it occurs?...when you select "strach" before nudge, when selecting "nudge" after that,
is does not leave the strach animation for nudge animation...it stop the image where it will be...
and this probably is not possible of being made (i don´t know)....
Referring to button "FX"...the button on the mixer it server to make only function the effect...the select effect FX has that to be select in tur turntable, in the part "effects" left button...
The effect select on display name on the "mixer" extended part....
The button "FX2 and FX3"...not have function because not is not possible to select two effect exactly the time....so...FX2 and FX3 do not function for while...therefore it is a question do VDJ 4.0...on VDJ 3.4 is possible three effects all time)...
It does not have nothing more to be made in skin!
Any thing, I am here...
Cristian
Cristian
geposted Sat 14 Oct 06 @ 9:59 pm
hey can you send me this skin? plz
geposted Sun 15 Oct 06 @ 1:31 am
good job :)
geposted Sun 15 Oct 06 @ 9:29 am
DJ-Norway,
I will send other skin with some changes......ok?! (to refer about FX effects....for don´t cause confusion...)...
Bye
Cristian
Bye
Cristian
geposted Sun 15 Oct 06 @ 7:03 pm
Sorry, it might be my fault ;)
I just tested it real quick..
Will test it again, see if it works like you say...
Might not need any more work, will check ;)
geposted Sun 15 Oct 06 @ 10:03 pm
Well...
I also tested here... and verified that the buttons "fx2 and fx3", that they did not have that to function, but are functioning as being "+" or "-", searching effect up and down...
It would not be the case of I to make this correction?
If "yes"....break the last file that I sended....
If "no"...ok....
Is with you......?!... :-)
Cristian
If "no"...ok....
Cristian
geposted Sun 15 Oct 06 @ 10:16 pm
hey can you send me this skin? Pleaze
Thx
Thx
geposted Mon 16 Oct 06 @ 1:13 pm
Ok.. it was a bit comfusing, as many buttons on the mixer are there for looks only, and dont have any functions ;)
Also, the nudge jogwheel dont seem to work. At least I can not nudge with it...
And the pitch slider is hidden by default. It only appears when hitting sync..
Before you do that, the slider is not there..
But, lets make this version available....
And any improvements need to be done, can be asked for here ....
Great looking skin ;)
geposted Mon 16 Oct 06 @ 4:41 pm
So..... I confess that...I was very stimulated...
I thought that... I was making one a skin for illumination control or table light, instead of sound control...
Here, the people ask all time "why you made in 1280??"...."why did made so large?"..."ohh...is nice...but...!"...
You knows how is .... Sometimes you make a lobster and the people is wanting rice and beans...
well, it is very possible that I make the one in 1024 x 768...so it will be more simply......
geposted Mon 16 Oct 06 @ 4:59 pm
has the skin been released . If so - where is is - can´t find it
geposted Mon 16 Oct 06 @ 7:26 pm
so...is a good question....?!
geposted Tue 17 Oct 06 @ 6:05 pm
Hello empregos,
Can you sent me the skin pls
geposted Tue 17 Oct 06 @ 8:26 pm
Dj Philly will make the exe a little bit later today... ;)
I tried, but ran into some errors.. lol ;) sorry..
Philly will fix it :)
geposted Tue 17 Oct 06 @ 8:45 pm
