Forum: Old versions
Topic: Hercules Sound
I purchased the hercules dj console and I need to turn the gain up higher than I would going directly through my other sound card which is a sound blaster external sound card and also the sound still isn't as full. Doesn't the dj console have a built in sound card; if so, is it not that good or what could be the problem? I am connected to 1 & 2 on the dj console and the other end to two channels on my mixing console.
geposted Mon 19 Jul 04 @ 12:26 am
Are your volume faders in the Hercules Mixer (green alien head) to the maximum?
macourteau
Yes, that was the problem. Thank you.
The only other thing I noticed is that I can scratch with the mouse and if I enable the stick that works too, but if I disable the stick and try to scratch with the jog wheel, instead of scratching it squeals. What could be the problem?
You can scratch with the jogwheels only with version 2 of VirtualDJ.
macourteau
