Forum: Old versions
Topic: Sorting Favorites Folders Problem
When I sort by BPM on a Favorites folder, and then click on a different folder and go back to the favorites folderm it's not sorted by BPM and I have to click to sort by BPM again. Can VDJ remember that the folder should be sorted by BPM so I don't have to click it every time.
geposted Sat 14 Oct 06 @ 11:53 pm
HaywardPRO InfinityMember since 2005
windows
start
run> regedit
hkey_current_user
software
virtualdj
autosort>rightclick>modify>value=3
geposted Sun 15 Oct 06 @ 3:22 pm
erxonPRO InfinityMember since 2003
Hayward wrote :
windows
start
run> regedit
hkey_current_user
software
virtualdj
Isn't that a permanent "solution" (rather setting), which isn't accaptable when you want to sort by artist next and browse through folders?
geposted Sun 15 Oct 06 @ 6:31 pm
Its for setting DEFAULT behaviour ;)
You can of course press column header, and sort by artist still..
but default sort will be changed
geposted Sun 15 Oct 06 @ 6:37 pm
Exactly, not really a solution :) Clicking the column itself should change that default setting, so when you browse through the folders it stays that way until you decide to change it again and click on another column.
geposted Sun 15 Oct 06 @ 7:36 pm
I think this is the same question for which I'm looking for an answer. When I select a folder, I'd like to see the music sorted by Artist. It can be extremely annoying when you have to continually click the column header every time a different folder is opened. Is there any way to change the default setting so that my folders are all sorted by Artist?
geposted Mon 16 Oct 06 @ 1:23 am
bump......anyone?
geposted Mon 16 Oct 06 @ 10:59 pm
different value...
Cant remember which, but think its 2
geposted Mon 16 Oct 06 @ 11:32 pm
