Forum: Old versions
Topic: Problem with video plug-ins
I am trying to get the new video plugins and none of them seem to be working. Of course, I have a feeling that I'm not installing them correctly. Basically, I click on the link to the effect name and run it, after which the install tells me that it's completed. However, when I try to use it in VDJ, I get a popup that tells me the application failed to start because of some .dll was not found.
Can someone tell me exactly how to get these plugins correctly?
Thanks in advance...
geposted Mon 16 Oct 06 @ 5:27 am
djcelPRO InfinityModeratorMember since 2004
Read the commentaries under the video effects ;-)
geposted Mon 16 Oct 06 @ 1:12 pm
I did, but it's still not working... :(
geposted Mon 16 Oct 06 @ 10:20 pm
If it asks you a dll, it means that you don't have the last update of DirectX 9.0c: you need at least june 2006
geposted Tue 17 Oct 06 @ 2:10 pm
Oh ok. Where can I get the DirectX 9.0 from?
geposted Tue 17 Oct 06 @ 5:26 pm
I'm still getting the following popup...
VirtualDj Video: Virtual DJ.exe - Unable to locate component
X
This application has failed to start because d3dx9_30.dll was not found. Re-installing the application may fix this problem.
Any ideas?
geposted Thu 19 Oct 06 @ 8:40 am
d3dx9_30.dll belongs to a last version of DirectX so use the link above and install it again
geposted Thu 19 Oct 06 @ 10:44 am
