wouln`t it be possible to generate a midiclock out signal to sync a grovebox ,or other aplications
to VDJ ? Would be a great opportunity.
Is it possible?
Is it possible?
geposted Mon 16 Oct 06 @ 11:34 am
yeh that would be cool!
geposted Tue 17 Oct 06 @ 11:31 am
It's possible to do that with a plugin. If I had more free time, I would do it, it isn't difficult, but you need a free MIDI port (the most cases is an integrated MPU401, which works perfectly), because I would use Windows multimedia APIs.
geposted Tue 17 Oct 06 @ 9:47 pm
nice one mate!
geposted Wed 18 Oct 06 @ 1:06 pm
@TexZK: would that be the midi out on Hercules DJC ? this I have and use it with the Asio driver.
I have the HDJC and a X session midicontroller and a extagy soundcard with midi so if one of the soundcards could send the signal , i could receive it in the x session wich I want to use to controll
Ableton.
\" it isn\'t difficult\" you write (for me impossible)
but then how come nobody did it until now. Is there another way to sync drumcomp.or Reason with
VDJ?
Thanks for your interrest.
I hope somebody can help me.
Ableton.
VDJ?
geposted Wed 18 Oct 06 @ 3:52 pm
