WIth the the new versions of virtual dj i cannot get any timecode signal. It sucks that i have to use the old virtual dj 3.4. Does anyone else have the same problem and were able to fix it ?
geposted Mon 16 Oct 06 @ 10:00 pm
yes , i have this problem 2 ,
i have not yet been able to sort it
geposted Mon 16 Oct 06 @ 10:08 pm
Have you tried lowering the volume of the timecode.mp3 with a sound editor (sound forge, audacity, cool edit, etc)? Have you set the latency to auto in the performance tab?
Try that and let us know your results. Good luck.
geposted Wed 18 Oct 06 @ 5:12 pm
General infomation :
Now Fixed in 4.1R2
read my guide if ur still having issues :) if you use turntables
https://virtualdj.com/forums/58092/General_Discussion/How_To_set_up_an_mk2_Console_With_TCV_IN_V4___the_ultimate_guide_.html
if u use cd use above genious advice :)
from carryshel
Now Fixed in 4.1R2
from carryshel
geposted Wed 18 Oct 06 @ 6:31 pm
that link doesn't work
geposted Wed 18 Oct 06 @ 9:46 pm
https://virtualdj.com/forums/58120/Hardware_Technical_Support/Guide_To_set_up_tcv_with_mk2_console__)_.html
its now been moved
sorry for any inconvience
its now been moved
geposted Wed 18 Oct 06 @ 10:11 pm
