Hey does anyone know how i can select specific effects to work with the ABCD effect knobs on the bcd2000? I dont know xml really i know i might have to fux with that a little bit.
geposted Tue 17 Oct 06 @ 9:49 am
in midi settings using the xml file previously loaded by you, you need to add or modify the bcd knob you want to apply the effect by just pressing it and searching for the function to use from vdj list.
geposted Tue 17 Oct 06 @ 2:37 pm
UMMM no clue how to do that. Got a lil tutorial?? hehe
geposted Wed 18 Oct 06 @ 10:36 am
Check this guide that says how to configure the bcd and how to use a xml file.
https://virtualdj.com/forums/57850/General_Discussion/A_quide_to_setting_up_BCD2000_in_Virtual_DJ_4_1.html
geposted Wed 18 Oct 06 @ 2:46 pm
how ken i play my effects on bcd 2000?
cant do it
cant do it
geposted Tue 14 Nov 06 @ 1:32 pm
80506944452 wrote :
yo
Dont spam!
geposted Fri 17 Nov 06 @ 2:10 pm
You can configure your effects with the knobs you want modifying the xml file :)
geposted Fri 17 Nov 06 @ 8:09 pm
