Forum: Old versions
Topic: Mk2 dj console substitute for maya
junjunHome userMember since 2006
Hi guys,
just had a quick question i wanted to check before purchasing the software. I'm currently running 2 numark ttxs on a numark matrix 3 mixer, and i'd like to use the TCV system from VDJ. i think all i need is a proper soundcard to hook up to my laptop, which brings me to my question, is the m2 console by hercules able to substitute for the maya 44? the maya is pretty hard to come by, and the esi sound card is quite a bit more expensive, i was just wondering if i could just pic up a mk2 console and use it solely as a sound card and use my existing tables and mixer for everything else? if that's possible, some insight as to how to hook it all up would be greatly appreciated!
cheers!
geposted Wed 18 Oct 06 @ 8:49 am
sbangsPRO InfinityMember since 2004
yes that would work fine :)
geposted Wed 18 Oct 06 @ 10:44 am
rEsKPRO InfinityMember since 2006
The real substitute of the maya 44 is the u46dj. I think is the best and cheapest solution if you're using external mixer & turntables with tcv's.
Great regards
geposted Wed 18 Oct 06 @ 12:08 pm
