Welcome
This is my guide for MK2 users who want to use TCV
The bits you need
Ok So now we are ready to begin
please go to sound set up and choose the options bellow
Now
please go to the proformance tab and select the following
Now please go to the mk2 control pannel
you will notice it as a litle Vinyl icon on your tast bar if you cannot see this go to startmenu , control pannel and then mk2 console
please select the below options
Now go back to the sound config and press configure tVC
press Auto congfig
Now hopefully all will be working :)
The bits you need
- mk2 console
- Virtual dj pro v4.3
- 2 or one TVC
Now
press Auto congfig
geposted Wed 18 Oct 06 @ 12:20 pm
i really appreciate this guide! now hopefully it'll work for me. i've been having a very difficult time with all this and it's been frustrating to get this all to work. hopefully you've hit the nail with the hammer with this one. thanks =]
geposted Fri 20 Oct 06 @ 8:58 am
thanks mate hope it sorts it for u!:)
geposted Fri 20 Oct 06 @ 3:00 pm
sorry, but can you show how to make all necessary connections, some diagram, having hard time to figure out.
thanks
thanks
geposted Wed 25 Oct 06 @ 4:57 am
geposted Thu 26 Oct 06 @ 8:28 pm
a lil diagram for u
geposted Thu 26 Oct 06 @ 8:30 pm
whats a chap do for timecoded cds??
thanks
DJ Rudra
thanks
DJ Rudra
geposted Fri 27 Oct 06 @ 5:55 am
for tccd
take the same steps
but in the timecode config choose tccd
not tcv
aslo put ur cd players instead of the vinyl players
take the same steps
not tcv
geposted Fri 27 Oct 06 @ 12:03 pm
thanks!!! that's help a lot. I will try as soon I get home.
santosac
santosac
geposted Tue 31 Oct 06 @ 5:03 pm
geposted Tue 31 Oct 06 @ 5:31 pm
BTW: Depending on the cd players sometimes tccd signal is too loud so you need to reduce it at least -12 db.
geposted Wed 01 Nov 06 @ 4:09 am
tnx :)
geposted Wed 01 Nov 06 @ 2:31 pm
So here is my question, which btw thanks for the guide skyfxl :-). Anyway, I can use the TCV normally, just playing songs straight up, but the scratching is basically nonexistent, when I touch the vinyl it basically just scratches nothing and the signal is gone until I take my hand off the vinyl, so my setup for right now with the TCV is:
(1) Numark TT200
(1) 2 Channel Mixer DM1002MKII
(1) TCV
(1) MK2 Controller
Here is the thing that may be causing the problem.... I'm using VDJ on a MAC with BootCamp? The specs are fine, but running VDJ on bootcamp I'm sure is sketchy.
Anyone have any specific settings change for what my problem may be?
Thanks!
(1) Numark TT200
(1) TCV
(1) MK2 Controller
Thanks!
geposted Tue 14 Nov 06 @ 8:06 pm
u need pro for full time code use sorry.
geposted Tue 14 Nov 06 @ 8:21 pm
I do have the pro version :-).
geposted Tue 14 Nov 06 @ 11:46 pm
then you have cracked it tsk tsk tsk
or you have neglected to add your serial here
https://virtualdj.com/fusers/modifuser.html
geposted Tue 14 Nov 06 @ 11:51 pm
mine keeps telling me the asio drivers are missing along with directio.dll is not found
geposted Tue 14 Nov 06 @ 11:53 pm
please reinstall your console edtion software
and the mk2 drivers
and the mk2 drivers
geposted Wed 15 Nov 06 @ 10:45 am
skyfxl wrote :
to use an external mixer in this setup
enable external mixer on the dj console
and pick 1/2 as left and 3/4 as right
geposted Wed 15 Nov 06 @ 11:47 am
was this guide helpful if so try
https://virtualdj.com/forums/59875/Hardware_Technical_Support/ultimate_guide_to_controllers.html
the guide to controlers :)
geposted Wed 15 Nov 06 @ 3:55 pm
