Hi
** Sorry I mis-posted this in hardware, whereas I think it's software - especially since it worked in 3.4 **
I'm using 4.1 along with a soundBlaster x-fi [as master out] and DJ Console Mk1 as my preview.
When i preview I can hear both channels in my headphones instead of just the "active deck".
I have my sound set up as:
- single input
- headphone and soundcard output
- 2 cards
- primary x-fi
- secondary DJC
- Primary card is main
- secondary card is preview.
Anyone know how to preview only one channel? (This use to work in 3.4)
Cheers
Jon
- single input
- 2 cards
- primary x-fi
- secondary DJC
Cheers
Jon
geposted Wed 18 Oct 06 @ 12:29 pm
Sound setup:
If you using external mixer:
Outputs:External Mixer
Sound Card(s):4.1
Front output is left deck, Rear output is right deck.
If you don't use mixer than:
Outputs:Headphones
Sound Card(s):4.1
Front output is Master out, Rear out is your headphones.
Hope this helps!
Sound Card(s):4.1
Outputs:Headphones
Sound Card(s):4.1
Hope this helps!
geposted Fri 20 Oct 06 @ 12:45 am
Hi
Before on go on I just want to say that 4.1rc2 has not solved my issues.
Below is an image of my sound setup.
To restate my isssue, I can hear both channels in my preview/headphones regardless of which devk is actuve.
Hope someone can enlighted me as I'm thinking about going back to 3.4
Thanks
Jon
Thanks
Jon
geposted Sun 22 Oct 06 @ 12:40 am
[Sorry [again] my image didn't work :) ]
Hi
Before on go on I just want to say that 4.1r1 hae not solved my issues.
Below is my sound setup:
Inputs: None
Outputs: Headphones
Sound Card(s): 2 Cards
Sound Card: SB X-fi Audio [CC00]
Second Card: Hercules DJ Console
Output Channels: Master:First Card / Headphones:Second Card
To restate my isssue, I can hear both channels in my preview/headphones regardless of which deck is active.
Thanks
Jon
Hi
Inputs: None
Outputs: Headphones
Thanks
Jon
geposted Sun 22 Oct 06 @ 12:59 am
input:none
output:4.1 soundcard
soundcard:hercules
master:rear output
headphone:center output
cheers
DJ Rudra
soundcard:hercules
master:rear output
cheers
DJ Rudra
geposted Sun 22 Oct 06 @ 6:26 pm
Ok
Is there anyway that I can use my x-fi as master?
Thanks
Jon
Thanks
Jon
geposted Tue 24 Oct 06 @ 6:49 am
I have a similar issue. Everything worked fine in v3.4, but when I upgraded to 4.1, I now hear the main output in the headphones, no matter what I do.
The difference for me is that I'm only using one sound card, the Hercules MK1. (I had an MK2 for a bit, but reverted to my MK1 when I realized that I didn't like it as much, but I can't seem to update my profile here at the site to reflect this)
VDJ v4.1r2
Inputs: None
Outputs: Headphones
Sound Card: DJ Console MK1
Output Channels: Master 1&2, Headphones 3&4
I also used to be able to get ASIO to work sometimes. Now it doesn't work at all.
I have a gig this Friday (10.27) and hope to get this resolved before then. Otherwise, is there a way to download v3.4?
Thanks in advance for the help!
Vince
VDJ v4.1r2
Inputs: None
Outputs: Headphones
Vince
geposted Tue 24 Oct 06 @ 3:41 pm
I have logged this in the bugs forum, under: 4.x Headphones/cue previewing both channels
geposted Fri 27 Oct 06 @ 4:26 am
vince..
sorry i did not see it earlier..
dunno much about the mk1..seems to me that the settings should work..
in order to download any version, current or previous, you have to contact eservice..find the link at the forum homepage in the software section
hope the gig went well all things considered..
cheers
DJ Rudra
cheers
DJ Rudra
geposted Fri 27 Oct 06 @ 7:38 pm
FIXDED!
On the cdj-700S skin there is a headphone mix slider [which I mistook for something else] Sliding this to the top meant that I only head the active deck through the headphones.
Jon
Jon
geposted Thu 02 Nov 06 @ 10:50 pm
hi everyone.. I was told that I can include a Eq in my Headphone mix. but im not so sure how to tweek my regirtry keys!. can someone help.. I need this cuz im just getting hi's on my headphones and very llittle lows..
geposted Fri 03 Nov 06 @ 2:28 am
https://virtualdj.com/addons/download.html?addon_id=2170
registry tool
thanks to dj cel:)
enjoy :)
registry tool
thanks to dj cel:)
enjoy :)
geposted Fri 03 Nov 06 @ 2:32 am
