Are there any news about the BCD-2000 Mapper?
Greetings
Tanzi
Greetings
Tanzi
geposted Thu 19 Oct 06 @ 11:54 am
Work in progress, don't worry man, mapper will be available as soon is possible from the user moramax ;)
geposted Fri 20 Oct 06 @ 9:41 am
at soon it'll be available a new bcd2000.....confirming what cioce said..
geposted Mon 23 Oct 06 @ 9:43 am
me gustaria tener plugins de efectos
geposted Sat 28 Oct 06 @ 10:15 pm
the new mapper is available:
http://www.virtualdj.com/addons/view.html?type=tool
geposted Mon 06 Nov 06 @ 10:14 pm
well done sir!
geposted Mon 06 Nov 06 @ 10:24 pm
I have downloaded it already works perfest.
But I was wandering what happens with the microphone buttons when this will work (e.g. ASIO driver updated)??
geposted Tue 07 Nov 06 @ 3:10 pm
@fmooij
when the drive will be updated we will study another solution!!! :) don't warry about!!! but it's too simple
for me think and update when driver will work for mic......
geposted Tue 07 Nov 06 @ 3:50 pm
Thank you in advance Moramax, we are waiting on the update for the mic to work
geposted Tue 07 Nov 06 @ 9:14 pm
Has anyone any idea;
1. If this is microphone in ASIO is committed by Behringer?
2. In what timeframe (weeks, montn) it will be available?
For the rest it is great fun playing with the bcd mapper!!!
Thanks
freek
Thanks
freek
geposted Tue 14 Nov 06 @ 6:24 pm
The Mic already works in Asio. It's VDJ which does not support Mic in Asio mode. What we need is WDM-mic drivers from Behringer or a VDJ wich supports ASIO-Mic.
geposted Tue 14 Nov 06 @ 11:26 pm
First I must say I love the way the BCD mapper has been made, well done.
Now a request for improvement.
1. When you press beatlock, button 24 for two seconds. It matches the pitch of the playing deck.
After mixing i want the pitch back to zero for better soundquality certainly in the case when keylock is on. The idea is in browser mode to have button 27 to reset the pitch to zero, so i do not have to use the mouse of the pc for it.
2. The Jog weel browser function is oke. However you can not browse the play list / side list.
An idea is to assign button 28 in browser mode to load the top number from the play list.
Or will there be a next generation mapper where you can assign your own BCD mapper, like the keyboard function in VDJ??
Regards,
Freek
Regards,
Freek
geposted Thu 16 Nov 06 @ 9:55 am
@fmooij
the next update that now is in beta testing i have added many others functions, improved others like loop led visualization, and the playlist browsing too(side list not possible for now).... i considering your request...but i don't know if i 'll implement in the 1.01 version but for sure i don't forgot for the next update.....
geposted Thu 16 Nov 06 @ 12:30 pm
it's available new update:
geposted Sat 18 Nov 06 @ 7:49 pm
moramax,
saw it downloaded it and will feedback the results.
freek
freek
geposted Mon 20 Nov 06 @ 8:20 am
To manage the playlists (browsing) we have to hold down the AIR button, meaning hard for me, two hands on the control. Could you change this to pressed for a few seconds and then release? (the led could be flashing too).
Thanks
PS Is there a bcd skin about to be released?
Thanks
geposted Tue 21 Nov 06 @ 12:29 am
@djdad
i consider your request....but i need others feedback to understand what user want before make other release....
it's my idea to make a skin for bcd2000 but for now i'm working to the mapper..i don't know when i'll start to do...
geposted Tue 21 Nov 06 @ 12:39 am
ok like yhe whole thing.
but on the next update would you consider this lay-out for the effects:
knob 34: adjust parameter 1, left deck
knob 35: adjust parameter 2, left deck
knob 36: adjust parameter 1, right deck
knop 37: adjust parameter 2, right deck
button 5: effect left deck on/off
button 6: effect right deck on/off
also on the 1.1 version if you (for example) activate backspin, when the backspin ends the led stay's on.
if you can fix that, it would be a verry verry nice thing!!!
thanx kevin
thanx kevin
geposted Mon 04 Dec 06 @ 7:43 pm
kevin56 why you have the mapper? This is not possible because you are "no licence user" !!!
Unistall your crack version and come back here regular http://www.virtualdj.com/purchase/
geposted Mon 04 Dec 06 @ 8:13 pm
@ Moramax:
I've dowloaded the mapper yesterday & tested it all half night long. It works fine. I just found a small detail in the doc about knob and butons inversion. Nothing serious.
The management for the folders and the playlist with jogwheels and A/B input buttons is great.
The browse mode with on air button is also a great idea.
Thx for this outstanding job.
geposted Wed 17 Jan 07 @ 4:56 pm
