Forum: Old versions
Topic: sound card problem
i'm sory my english is not so good!!!
how do i make the headphons and the speakers work seperetly?
i have creative live 5.1
and i have set my sound card to 4 speakers?
geposted Thu 22 Jul 04 @ 3:53 pm
This feature is not available in the trial version. It works great in the full version. Even if you have only 1 stereo sound card.
hello i have virtual 1.09 i have 2 sound cards on pc one from motherboard and the other i added creative audigy when i try to click on the 2 sound card setup so that i can use the second sound card for the Qing of second turntable but each time i try it i get sound from my main speakers ! i'm not getting any sound from the second sound card where my headphones are hook up to ! when i do it from the main soundcard the the headphone volume is way to low ! what do i need to do to bring up the volume leaval and get use of the second soundcard !
Protrucker: Your problem may be with the illegal version of the software that you are using.
I have the same problem. I received Virtual DJ by buying the DJ console. Does this mean I have a trial version?
I have a licens, I updated my profile...sorry. It did not work the first time.....
problem solved, thanks anyway :o)
cheers
pinki
U dont have a trial version, but a console version..
the version is specially made for the console, and have no time-limit (like trial/demo).
It's a working version that u can have use w/ console.. But have some limitations compared to full version. In full version you can have 2 stereo outputs for external mixer, scratch with jogwheels, full access to skins and effects etc ;)
but still, its a working version u got, that works very well with the console :)
