Forum: Old versions
Topic: DJC Mapper for MkII
Hello
I have just purchased Virtual DJ 4.1 r2 to enable me to download the DJC mapper to reassign my Cue Button to a STOP(&cycle through cues).
I downloaded and installed the mapper. Went to EFFECT / EXTERNAL DEVICES and started mapper. I can reassign keys and apply. However, this has no effect at all - no changes to the MkII buttons.
What am I doing wrong?
Thanks
geposted Fri 20 Oct 06 @ 4:15 pm
MuelusPRO InfinityMember since 2005
sam eproblem here but im on the mk 1 console.
I downloaded the djc 4.0 + mapper but doesnt assign functions to my console for some reason.
The old version used to work ok but the updated version doesnt work.
geposted Sun 22 Oct 06 @ 6:01 pm
With DJ Console it works
geposted Sun 22 Oct 06 @ 6:12 pm
Try in mode ASIO ... !
Actually im using VDJ 4.1r2 + mapper 4.1 HDJC MKI
Only worked in Asio mode..
Good luck
geposted Sun 22 Oct 06 @ 10:54 pm
I'm having the same issue. The mapper has no effect.
I've also found another oddity.
If I disable the Hercules DJC in settings, then renable it the mapper will work but the CPU usage goes up to 100% and stays there until I shut down VirtualDJ and restart it, then of course the mapper does not work again.
Steve
geposted Sun 05 Nov 06 @ 3:00 am
djcelPRO InfinityModeratorMember since 2004
Yes i already know it
geposted Sun 05 Nov 06 @ 11:10 pm
Cool, at least I know it's not just me!
geposted Mon 06 Nov 06 @ 3:43 pm
ReTangoPRO InfinityMember since 2006
same here! i thought i was doing something wrong!!
geposted Mon 06 Nov 06 @ 6:21 pm
frd1963PRO InfinityMember since 2004
Cel,
Thanks for your work on the MK2 mapper for v4.1
Even with its high cpu usage, it makes my job alot easier. I have been able to remove 2 midi controllers by remapping some of the knobs and buttons of the MK2.
Do you need any feedback or logging to help resolve the cpu issue? If so, let me know. I use the mapper for at least 4 hours each week, usually much more.
-Frd
geposted Wed 08 Nov 06 @ 6:20 am
DJ Cel,
I too appreciate all your work, in fact I am just now begining to realize how much I've come to depend on the mapper for videos!!
I'm sure you are doing your best to correct the problems ASAP. Do you have a rough estimate as to when you might have a new version? I'm just trying to decide if I should wait or figure out a way around it.
Thanks
Steve
geposted Wed 08 Nov 06 @ 6:01 pm
Hercules is already working on a driver update;)
geposted Fri 10 Nov 06 @ 9:38 am
sbangsPRO InfinityMember since 2004
geposted Fri 10 Nov 06 @ 11:38 am
Hi DJCel, thanks for the work! I could beta test your mapper, just tell me, regards...
geposted Wed 22 Nov 06 @ 3:47 pm
I have already uploaded a v4.1.1 on the website
geposted Wed 22 Nov 06 @ 7:26 pm
