Hello,
this problem is a bit strange. I use my Virtual DJ 1.09 in the NOT scratching mode (just for techno beat matching). Sometimes after I finish music "balancing" and bith tracks goes fine (good speed) one deck starts to sppeds up just like I would turning the wheel. Something like I accidentaly hit the wheel with my hand but I do not that!
This usually happens in the best mix :(
Whats wrong? It looks like a mouse bug ... when you put a cheap mouse under the strong sun light, the cursor sometimes makes errors (jumps). Is that a bug in software or in the console (in MY console???).
geposted Thu 22 Jul 04 @ 7:46 pm
This is a known bug, that Hercules can fix, but you have to send them back your console. Search for 'hypersensitive' jogwheels in this forum you'll see ;)
https://virtualdj.com/forum/display.html?topic=3555
macourteau
macourteau
geposted Thu 22 Jul 04 @ 7:52 pm
Well this is not my problem. The decks doesnt stop...
For example when I try to press PITCH + or - several times (quick), Virtual DJs pitch time up is much longer sometimes. This can totally break your mix up...
geposted Thu 22 Jul 04 @ 9:33 pm
