please sombody help, i just bought my stanton t.80 turntables with a pre-amp mixer (rm-404) i need to know what to do next to hook it up to virtual dj. the question is should i buy the u46dj or hercules mk2
geposted Sat 21 Oct 06 @ 10:26 pm
Depends on how you mix, if you need the controller functions (cue, loop, play, jog wheels, etc etc) and don't scratch very much the mk2 will work. But I recommend the u46dj if you're looking for low latrency, dependable TCV usage. The mk2 has really slow asio drivers, many scracthes on the mk2 will sound overly digitised;^]
geposted Sat 21 Oct 06 @ 10:40 pm
wow, i have alot to think about now that i've read timmy's comment about the mk2, cuz i scratch alot and want great quality sound. i will be satisfied if i can get my set to comply wit vdj. on the side note... anyone here know how to connect an external mixer to vdj?
geposted Sun 22 Oct 06 @ 1:04 am
