Forum: VirtualDJ Plugins
Topic: stop effects
bogartPRO InfinityMember since 2004
I have downloaded the sonique effects. Have them working, however every time I open VDJ the sonique effects load. How can I stop the effects from loading & runing?
geposted Sun 22 Oct 06 @ 7:55 pm
djos06PRO InfinityMember since 2005
Hi bogart,
If you want to stop the load of an effect , you just have to remove it from the Plugin/ repertory of Virtual DJ : C:\Program Files\VirtualDJ\Plugins\SoundEffect
geposted Thu 26 Oct 06 @ 10:02 am
My bad I forgot to post that I have found the answer.
ALl you have to do is go to the Video Tab and uncheck the box
that says "Activate On Load"
geposted Thu 26 Oct 06 @ 6:48 pm
Alguem ae fala portugues?
Help!
geposted Thu 02 Nov 06 @ 5:31 pm
phillydjPRO InfinityModeratorMember since 2004
geposted Thu 02 Nov 06 @ 10:27 pm
ghrey17Home userMember since 2006
hi there
geposted Sat 11 Nov 06 @ 11:58 am
sbangsPRO InfinityMember since 2004
ghrey17 wrote :
hi there
hi :)
geposted Sat 11 Nov 06 @ 3:32 pm
