Forum: Old versions
Topic: i got my tcvs working but....
in the program the bpms flutuate up and down a little and when u start a song it doesnt start at normal bpm ? it will be like %1.3 but everyhting is working i can adjust with pitch on turntable
also before i was having problems of just reciveing tcv sounds and stuff and no music this is what i did i reseated my cartidges like 6 times looking at the aiso graph and touching the viynl till it got good signal then lock in place then i made sure u46dj is on phono input on sound card esi u46dj and on the mixer it is line.
ALSO the new drivers wont work if u have 050 rev of the card which i have u have to use 1.1.14 drivers :)
my main question is why the fluctuations just normal?
geposted Sun 22 Oct 06 @ 8:59 pm
hi there could u add ur Tcv to ur profile ,by pressing detect TCV
then ul have a lil cool icon lol
and what needles do u use?
i cant because it is on a diffrent computer (my laptop) and that is not hooked up to the internet all i can do is take a picture lol
i am using numark cc-1 brand new :)
and the flucuations are like this 142.3 bpm then it goes to .4 then .5 then it will go to .4 then to .3
doesnt matter lol , go to ur profile and press detect mk2 order
checked conectors are grounded ?
yes everything works fine no hums no feedback nothing bad like that everything is working in the program with the tcv its just that bpms fluctuate as i stated above and i just got these tcv's so i just wanna know if thats normal.
what do you mean check mk2? i dont have a mk2 i just have u46dj
To have TCV show on your profile go here https://virtualdj.com/fusers/modifuser.html
It doesn't matter which computer you're using, if you ordered TCV from virtual DJ it will show up after you click on TCV detection;^]
Yes. Its because of the wow and flutters on turntables.
Wow and Flutter are common on turntables. Flutter is the fast variation of pitch commonly caused by the push/pull distortions caused by the magnets that drive a DD turntable motor. Wow is the slow variation of pitch caused by things like a mis-aligned platter, off center spindle holes in a record, off center pressings, record warping, or defective regulators in the DD motor.
In a properly working turntable, NEITHER wow or flutter have any effect at all in your mixing.
The most common cause of wow is record defects (bad pressing, warped vinyl). Try the other side of your VDJ tc vinyl, and see if it works better.
(although the fluctation you mention seems very little, and in nature of a turntable)
UHHHH it says that this email isnt withthis vinyl or some shit wtf ??? well i didnt order with my credit card my friend did for me cause he has one and i just gave him the money so wtf... i gotta make a new account with his email to get support?
thx alot norway :)
I belive you;) so you have timecode icon now ;)
Also, if fluctations are too bad, try lower the asio buffer, at the U46dj.
And always use AUTO for latency in VDJ, with that soundcard..
o um .... well. i haveto use old drivers cause i have the old rev and it doesnt have settings in u46dj to change that stuff so gotta do it in vdj but maybe there is regestry setting and thx for the icon
Never mind that then ;)
It wont really "fix" any flutations, thats turntable related.
I was only thinking you had a latency problem, and that the wow & flutter at the turntable was not really the issue ...
Just test if you can mix well, and you might see that the natural wow & flutter dont matter;) It should not on good turntables...
